11.1.6.2.10.3 Pre-Conditions for a Batch Group
You can schedule the batches and set the pre-conditions within a Batch group with frequency as Weekly, Monthly, or based on an Interval for scheduling the batches. The batch that satisfies the configured pre-conditions are executed as part of the schedule.
Pre-Conditions can only be applied when using the Schedule option in the Schedule Batch window.
Weekly
To set the pre-conditions to the batches in a batch group weekly, perform the following steps:
  1. In the Schedule Batch window, you can select either Once, Daily,Weekly, Monthly, or Cron Expression option based on the schedule that you want to run the batch group.
  2. Select the Batch Group you want from the Select drop down menu.
  3. Enter a Schedule Name.
  4. Specify the other details displayed when you are selecting Once, Daily,Weekly, Monthly, or Cron Expression.
  5. Click Pre-Conditions.
  6. In the Pre-Conditions window, specify the Batch from the drop down and from the Frequency drop down and select Weekly.
  7. Select the days from the Select Days drop down that you want to schedule the batch run within the selected week.
  8. Click Add to add the specified entry.
    Pre-Conditions can be added only to one batch at a time.
  9. Click Save.
    The batch is executed based on the configured pre-conditions.
Monthly
To set the pre-conditions to the batches in a batch group monthly, perform the following steps:
  6. In the Pre-Conditions window, specify the Batch from the drop down and from the Frequency drop down and select Monthly.
  9. Click Save.
Interval
To set the pre-conditions to the batches in a batch group based on an interval, perform the following steps:
  6. In the Pre-Conditions window, specify the Batch from the drop down and from the Frequency drop down and select Interval.
  7. Select the interval from the Custom Recurrence (Repeat every) Days drop down that you want to schedule the batch run within the selected week.
    The Custom Recurrence can be set maximum to 60 days.
  9. Click Save.
  10. The batch is executed based on the configured pre-conditions.
