11.1.4.5.2.2 Copy a Batch Group
The Copy Batch option allows you to copy a Batch that you want to clone or create instances in the system from the Define Batch window.
To copy a Batch Group, perform the following steps:
  1. In the Define Batch window, click Batch Group option to list the batch groups.
  2. Click Copy Batch corresponding to the Batch Group that you want to copy.
    The Copy Batch window is displayed.
  3. Specify the Batch Details as you want to clone and copy the existing batch.
    For more information, see Create a Batch Group section.
  4. Click Save.
    The copied batch group is saved and displayed in the Define Batch window.
