10.5.16 Delete Objectives and Draft Models
To delete Objectives and Models that exist in the Objectives, follow these steps:
  1. Click Launch Workspace next to the corresponding Workspace to display the Dashboard window with application configuration and model creation menu.
  2. Click Model Pipelines to display the Model Pipelines window.
    The window displays objectives that contain models and model records in a table.
  3. Click Action next to corresponding record (objective/draft) and select Delete.
  4. You can select two or more objectives or models from the records.
  5. Click Delete to display the Delete dialog box.
  6. Click Delete to delete or click Cancel to cancel.
    Figure 10-94 Delete Objects screen
    This image displays the Delete Objects screen.
    If the Model is promoted to Production, you cannot delete the model even it is retired.
