8.2.6 Inspect a Conda Environment To inspect a Conda environment: Click Conda Environments to navigate to Environment Summary page from any other window in the application.This page displays the Conda environments in a table. Click Actionnext to corresponding environment and select Inspect to edit the details. Note:The Inspect option is not displayed for the Conda environment whose creation status is Create. The Conda environment details are displayed. Figure 8-20 Conda environment details You can perform the following in the above page: Remove Environment Clone Environment Export Environment Edit a Conda Environment Description Add or Remove the Environment Tags Search All Packages View Package Properties Update Package Remove Package
