11.1.4.2 Manage Batch
You can manage a batch by editing, copying, or delete them as required.
  • Edit: Use the Edit Batch icon to edit the Batch Description, Service URL Name, Service URL. You can also add a new batch parameter. You cannot edit seeded batches.
  • Copy: Use the Copy Batch option to copy a Batch that you want to clone or create instances in the system from the Define Batch window.
  • Delete: Use the Delete icon to delete a Batch that is no longer required in the system. You cannot delete seeded batches.
