PreviousNext
JavaScript must be enabled to correctly display this content
8.2.9 Modify Conda Settings
To modify the Conda Settings:
Click the Conda Environments icon to navigate to the
Environment Summary page from any other window in the
application.
This page displays the Conda environments in a tabular
format.
Click the Conda Settings icon.
The Manage Conda screen is
displayed.
Figure 8-26 Manage Conda screen
Select the required option and click Clean.
All: Removes index cache, lock files, unused
cache packages, and tarballs.
Index Cache: Removes index cache.
Packages: Removes unused packages from writable
package caches. WARNING: This does not check for packages installed
using symlinks back to the package cache.
Tarballs: Removes cached package tarballs.
Log Files: Removes log files.
This will clean up the Conda components based on the selection.
