10.5.12.4 SS $RUNSK support for processing Delta Data by Data Pipeline and Match Rules
A new parameter to pass RUNSK is being implemented in the Scheduler UI.
Dynamic Parameters screen for new batches are created.
- RUNSKEY will be present in Task Parameters while copying task for existing batches.
- RUNSKEY should be visible in View Execution Parameters - Task Parameters in Monitor screen.
- RUNSKEY will change just as BatchRunID in "Rerun" Case.
- RUNSKEY will remain same just as BatchRunID in "Restart" Case.
- RUNSKEY will be stored for batches in "AAICL_SS_BATCH_RUN" in column "N_RUNSKEY".
