10.5.4.1.1.2.6 View a Pipeline
The Pipeline canvas window allows you to view the Pipeline using the following options:
- Auto-align: Arrange all the widgets in vertical order. After saving, the reverting option will not work.
- Revert-align: Revert all the widgets if they are Auto-aligned.
- Refresh: Refresh the pipeline canvas.
