Configure Operating System and File System Settings
To install the application, configure the operating system and file system settings refer the parameters and configuration actions.
Table 4-1 Configure operating system and file system settings
| Parameter | Configuration Action |
| File Descriptor Settings |
In the
fs.file-max = <value> where <value> is greater than 15000
# /sbin/ sysctl -p Note: The value specified here is the minimum value to be set for the installation process to go forward. For other modules, this value may depend on the available resources and the number of processes executed in parallel. |
| Total Number of Process Settings |
In the Note: The value specified here is the minimum value to be set for the installation process to go forward. For other modules, this value may depend on the available resources and the number of processes executed in parallel. |
