Installing Conda
Conda as a package manager helps you to find and install packages. With the
capability of environment manager, you can set up a totally separate environment to run
different versions of Python. In addition, you can continue to run your usual version of
Python in your normal environment.
The supported version is 4.14.0.To install the Conda, perform the following:
