Java Settings
To configure the Java Settings, refer the following table:
Table 4-2 Java Settings
| Description | Example Value |
In the .profile
file, set JAVA_BIN to include the JDK absolute
path.
For example: JAVA 17 |
Table 4-3 Java Settings
In the Ensure that SYMBOLIC links to JAVA installation are not set in the PATH variable. |
In the .profile
path.
For example: JAVA_BIN
