Prerequisite for Data Pipeline
The below are prerequisites for Data Pipeline. The steps need to be
executed before triggering MMG Installer.
- Log in as DB user(ex: fccmdb) in your DB server (For example: 1759).
- Create one directory with preferred reference name (For example: datapipline) at the preferred location.
- Now execute below commands in putty session of DB server:
mkdir -p ##location of dir created in step 2##/file_store/fs_list/logs #A directory by the external table to write the logs.mkdir -p ##location of dir created in step 2##/file_store/fs_list/script #A directory to hold a pre-processor script used to list the files in a directory. This needs Read-Execute permissions.mkdir -p ##location of dir created in step 2##/file_store/fs_list/control #A directory to hold files to control which directories can be listed. This needs Read permissions.mkdir -p ##location of dir created in step 2##/file_store/fs_list/fccm-data #A directory to store the csv files.
- After that login to DB server(For example: 1759) as sysadmin( For example: sys)
in sqldeveloper or any preferred application execute below:
- CREATE OR REPLACE DIRECTORY fs_list_logs_dir AS '##location of dir created in step 2##/file_store/fs_list/logs';
- GRANT READ, WRITE ON DIRECTORY fs_list_logs_dir TO ##MMG Application Schema##;
- CREATE OR REPLACE DIRECTORY fs_list_script_dir AS '##location of dir created in step 2##/file_store/fs_list/script';
- GRANT READ, EXECUTE ON DIRECTORY fs_list_script_dir TO ## MMG Application Schema##;
- CREATE OR REPLACE DIRECTORY fs_list_control_dir AS '##location of dir created in step 2##/file_store/fs_list/control';
- GRANT READ ON DIRECTORY fs_list_control_dir TO ##MMG Application Schema##;
- CREATE OR REPLACE DIRECTORY external_tables_dir AS '##location of dir created in step 2##/file_store/fs_list/fccm-data';
- GRANT READ ON DIRECTORY external_tables_dir TO ## MMG Application Schema##;
- GRANT CREATE TABLE TO ##MMG Application Schema##;
Once the above steps are done, trigger the installation of Compliance Studio build.Note:
- If the new schema is residing on any-other DB server other than the one on which above steps were performed. Please perform all the above steps on that respective server.
- Once configured the DB server, if new schema is created on it. Need to perform the step for the respective schema.
