5 Access MMG from Analytical Applications Infrastructure
You can now access the MMG Application and its features from AAI.
Prerequisite
  • To access the MMG application from AAI, log in to My Oracle Support, and search for 36336349 patch under the Patches & Updates tab, download and apply it.
  • A valid MMG setup should be up and running.
Embedding the OFS MMG UI from the OFS AAI page is supported only when both OFS AAI and OFS MMG use the same protocol (either both HTTP or both HTTPS). Mixed protocol usage may cause authentication/session failures due to browser security restrictions.
To access the MMG application, perform the following steps:
  1. In the AAI Configuration Schema, update the value for MMG_UI_URL, and MMG_SERVICE_URLin the nextgenemf_configtable with the values in the MMG installation.
    Example:
    •  MMG_UI_URL:http(s)://<FQDN/IP>:<mmg_ui_port>/<mmg_context_name>/home
    • MMG_SERVICE_URL :<FQDN/IP>:<mmg_be_port>/<mmg_context_name>
      If the target MMG is using secured connection, import the target server certificate to the AAI application Java Truststore and restart the services.
  2. You must map the MMGACCR role to the required user. In addition, MMGACCGRP group is preseeded with the above role.
  3. You must map the OFS_MMG_HOME Menu ID to the desired Parent ID in the AAI_MENU_TREE table in the AAI Configuration Schema.
  4. Restart the AAI services.
    After successful login to the AAI application, a menu named Model Management and Governance is displayed. Based on your menu tree configuration, the left pane is displayed as shown below:
    Figure 5-1 Model Management and Governance menu
    This image displays the Model Management and Governance menu.
  5. When you click on Model Management and Governance, the MMG Login page is displayed, enter the credentials to access the MMG application.
