Cache User's Dataframe from Notebook
A user-made data frame can also be cached using the below API. It will be stored in the datastudio server in location : $DS_HOME/work/ftpshare/mmg/workspace_name/cached/tag. The dataset will be saved as a parquet file with name cached_tag.parquet.
This dataframe is not related to dataset created from UI. This is independent of dataset metadata.
Table 11-11 Cache User's Dataframe from Notebook
API Notebook Script Notes/Input
Caching Data Frame
from mmg.datasets import cache_df
path=cache_df(df, tag)
path
df = dataframe to be cached - pandas dataframe
tag - string
