Create a Batch Group
You can create a new batch group in the Define Batch window and schedule and
monitor the batch group that you created.
To create a new Batch Group:
- In the Define Batch window, click
Add.The Create a New Batch window is displayed.
- Select Batch Group option.
- Specify the following fields:
- Name
- Description
- Add Batches: This is a multi-select field. You can select the batches that you want to add to the group using this field.
- Notify on mail
The Add Batches is a multi-select field, you can select the batches that you want to add to the group using this field.Choose the desired option to notify by an e-mail the batch execution status depending on the property selected. E-mail for the email notification is fetched from the IDCS configuration for the logged in user.Note:
E-mail is a mandatory field in IDCS.The BATCH_NOTIFY_FUNCT function must be enabled to access this feature.If it is not available for the logged in user, this field is grayed out.- Every Time: An e-mail is triggered irrespective of the batch status.
- Never: No e-mail will be triggered.
- On Error only: An e-mail is triggered only when the batch execution has failed/Error.
- On Interrupt only: An e-mail is triggered if the batch is successfully interrupted.
Never is the default option. - Click Save.The new Batch Group is created and displayed in the Define Batch window.
