Create a Credential
New credentials are created when database details are changed or updated. For example, change in Transparent Network Substrate (TNS) due to hostname change or compulsory periodic update of schema passwords.
Oracle Wallet provides a simple and easy method to manage database credentials
across multiple domains. It allows you to update database credentials by updating the
Wallet instead of having to change individual data store definitions.
To create a new password credential for the wallet, follow these steps:
To create a wallet credential, follow these steps:
- Click Create. The New Credential dialog box is displayed.
- Enter the following information in the New credential dialog as
tabulated in the following table.
Table 9-8 Create Credential dialog box
Field Description Name Enter the name for the wallet credential. Type From the drop-down list, select the Oracle Wallet type. File Upload the wallet zip file that includes the following files: tnsnames.ora
ewallet.p12
cwallet.sso
These files are available in the
<COMPLIANCE_STUDIO_INSTALLATION_PATH>/wallet
directory.Note:- The wallet file must be in .zip format.
- The maximum file size allowed for the credential file is 128Kb.
- Click Create. The wallet credential is created and displayed on the Credentials page.
