Create Objective (Folders)
Create folders called Objectives within which you can create Models.
To create an Objective, follow these steps:
  1. Click Launch Workspace next to the corresponding Workspace to Launch the Dashboard window with application configuration and model creation menu.
  2. Click Model Pipelines to display the Model Pipelines window.
    The window displays folders that contain models and model records in a table.
  3. Click Add and select Objective from the list to display the Objective Details dialog box.
    Figure 11-70 Select Objective from Add
    This image displays the Select Objective from Add.
  4. Enter details in Objective Name and Description fields in the Add Objective dialog box.
    Figure 11-71 Objective Details Dialog box
    This image displays the Objective Details Dialog box.
  5. Click Save.
