md Interpreter
This Interpreter displays text based on Markdown, which is a lightweight markup language. In the md interpreter, you can configure the markdown parser type. Markdown (md) is a plain text formatting syntax designed so that it can be converted to HTML. Use this section to configure the markdown parser type.
To configure the md interpreter variant, follow these steps:
  1. On the md Interpreter page LHS menu, select md. The md interpreter pane is displayed.
  2. On the Interpreter Settings page, expand Interpreter Client Configurations and click the Edit icon for <Class Name> (zeppelin). The Interpreter Client Configurations Window is displayed.
  3. Enter the markdown parser type and click Update. To confirm the modified configuration.
