Java Settings
To configure the Java Settings, refer the following table:
In the application, Java 21 is supported.
Table 4-2 Java Settings
Description Example Value
In the .profile file, set JAVA_BIN to include the JDK absolute path.
For example: JAVA 17
Table 4-3 Java Settings
In the .profile file, set the Java tool options for all versionsJDK-17 and above updates.
Ensure that SYMBOLIC links to JAVA installation are not set in the PATH variable.
JAVA_TOOL_OPTIONS=" -Djdk.util.zip.disableZip64ExtraFieldValidation=true"
export JAVA_TOOL_OPTIONS
For example: JAVA_BIN =/usr/java/jdk-17/bin
export JAVA_BIN
