Import/Export Parameter Sets using Utility
You can import and export the parameter sets between Sandbox to Production or vice versa using the Utility.
Prerequisite:
Before you import, ensure the Parameter Sets artifacts are available in the <installed path>/ftpshare.
To import the parameter sets:
  1. Navigate to <MMG_PACK>OFS_MMG/binand execute in the following format:
    ./parameter_set_export_import_utility.sh IMPORT TARGET_WORKSPACE LOGIN_USER LOCALE FILE_NAME OBJECTIVE_ID OVERWRITE_FLAG
    Example:
    ./parameter_set_export_import_utility.sh IMPORT CS SAUSER en_US CS_1638105398036_set-1 1638105398036 true
    Table 11-26 Fields and icons on the Sandbox Summary page
    Field Description
    Import Command to import the Parameter Set into Workspace
    Workspace The name of the Workspace to which you are importing the Parameter Set
    Login_User The logged in user name.
    Locale The application language preferences
    For example: en_US
    File_name The file name with the following format:
    Workspace name_Objective ID_Threshold Code
    For example: CS_1638105398036_set-1
    Overwrite_Flag To be set True, if existing threshold has to be overwritten. Else, False.
    To export the parameter set, perform the following steps:
    Prerequisite:
    Before you export, ensure the Parameter Sets are available in the UI / setup.
    1. Navigate to <MMG_PACK>OFS_MMG/bin and execute in the following format:
      ./parameter_set_export_import_utility.sh EXPORT WORKSPACE LOGIN_USER LOCALE THRESHOLD_CODE OBJECTIVE_ID
      Example:
      ./parameter_set_export_import_utility.sh EXPORT CS SAUSER en_US set-1 1638105398036
      Table 11-27 Fields and icons on the Parameter Set page
      Field Description
      Export Command to export the Parameter Set from the Workspace
      Workspace The name of the Workspace from which the Parameter Set is exported
      Locale
      The application language preferences.
      For example: en_US
      Threshold Code Parameter Set Name
      Objective ID The Objective ID
