8.2.4.2 Use Case Flow for Outliers Analysis
You can refer this use case to best leverage the advanced analytics capabilities of the reports.
Starting from the canvas “Financial Statements – Outliers” you can perform a series of actions as following described.
  1. Select your desired Sigma value on which the outlier analysis will be generated.
    Figure 8-33 Sigma Value Selection
  2. Select the Financial Statements, as described in the previous section Working with Financial Statement Reporting Lines.
    Figure 8-34 Financial Statements Selection
  3. Select the Outliers and change the desired Hierarchy level for any of the available Key Processing Dimensions.
    Figure 8-35 Outliers Selection
  4. After you have selected a combination of outliers and related Dimensions, you can use the Data Actions to navigate to the other Report Canvases.
    Figure 8-36 Navigation to Report Canvases
