14.1.1.2 Allocation Model Specification Pane
The Allocation Model Specification pane displays a table containing all the Allocation Models that meet the search criteria. The Allocation Model Specification summary table offers several controls that allow you to perform different functions when you select an Allocation Model.
To select an Allocation Model, click a check box in the first column of the table. You can select more than one Allocation Model at a time, but this disables some of the controls. Click a check-box a second time to deselect the Allocation Model. You can select or deselect all of the Allocation Models in the summary table by clicking the check-box in the upper left-hand corner of the summary table directly to the left of the Name column header.
  • Add: Click Add to build a new Allocation Model. The Add icon is disabled if any rows in the table have been selected.
  • View: Select a single row from the table to enable the View icon. Click View to view the contents of an Allocation Model on a read-only basis. The View icon is enabled when a single Allocation Model is selected.
  • Edit: Select a single row from the table to enable the Edit icon. Click Edit to modify a previously saved Allocation Model. The Edit icon is enabled when a single Allocation Model is selected.
  • Delete: Select one or more rows from the table to enable the Delete icon. Click Delete to delete the models you have selected.
  • Run: Select a single row from the table. Click Run to execute the selected Allocation Model. The As-of-Date that applies to the model's execution is visible in the upper right corner of the screen and you can reset it in the Application Preferences for Profitability Management. The Run icon is enabled when a single Allocation Model is selected.
  • Check Dependencies: Click Check Dependencies to generate a report on any rule objects that depend on the Allocation Model you have selected. The Check Dependencies icon is enabled when a single Allocation Model is selected.
