13.9.1 From Management Ledger to Management Ledger
For Static Driver allocation rules, Management Ledger-to-Management Ledger is a common use case. Allocate 15% of the occupancy expense from one cost center to another cost center. In this example, the static driver is 15%.
Create a cost pool by aggregating 25% of the expense found under a select group of General Ledger accounts for a region or a division or a department, or a single cost center. In this kind of aggregation, the static driver is 25%. Transfer 100% of loan assets from all loan origination centers within a region to a regional holding center. In this example, the static driver is 1.
While such allocations are relatively common when you have a series of such allocations utilize Static Driver Table rules. Using a Static Driver Table rule, you can accomplish with a single rule what might otherwise require dozens or even hundreds of Static Driver allocation rules.
