7.4 Running a Simplified Batch
To run a Simplified Batch from the Simplified Batch summary page, follow these steps:
- Select a Simplified Batch from the Simplified Batch summary page.
- Click Run to execute the batch.
- A confirmation message is displayed. Click Yes to proceed, or No to return to the Simplified Batch summary page.
- After clicking Yes, a Date Selection window is displayed. Select the appropriate date for use in processing. The Date defaults to the System Date. To change the Date, either directly enter a date in the format displayed, or use the Calendar tool. You can ignore the message Please select a date if you have included Extract Data or Transform Data tasks in this batch.
- Click OK.
- A confirmation message is displayed. Click OK.
- You can monitor the status from the Simplified Batch summary page or the Simplified
Batch details page.
- To monitor the status from the Simplified Batch summary page, click Refresh. The summary page will update the Last Execution Date with the current date and the Status at completion (for example, Complete, or Failed if there was a critical problem).
- To monitor the status from the Simplified Batch details page, see the Viewing the Task Logs section.
This currently applies to all task types except Extract Data and Transform Data.
