16.7.5 Running Existing Threshold Sets
You can run a simulation for existing scenario threshold sets.
To run the threshold simulator for an existing scenario threshold set, follow these steps:
  1. In the All Thresholds page, select the check box corresponding to the threshold set you want to run the simulator for.
  2. Click Open Simulator. The Simulator Conditions pop-up window displays.
    Alternatively, you can also run existing threshold set from the Simulation Details tab by clicking Open Simulator. The Simulator Conditions pop-up window displays.
  3. Provide the following details:
    1. Select the Batch Date as the date for the data you want to test the thresholds against. This can be the current date or a past date.
    2. Enter the Data Origin.
    3. Select one or more Jurisdictions for this threshold set using the drop-down list. Jurisdiction refers to the division of data in the database based on criteria such as geographical boundaries, legal entities, and so on.
    4. Enter the Lookback Period for this threshold set. Lookback period refers to the number of seconds, minutes, hours, or days to lookback from the current date or time to create a time window which is used to consider cases for correlation.
    5. Enter the Frequency Period for this threshold set. Frequency period refers to how frequently the scenario should be run.
    6. Enter any comments you have for this threshold set.
    7. Enter the threshold values you want for this threshold set in the New Value field.
  4. Click Save & Simulate to run the modified simulation. After running a simulation, the Simulator History window displays the result with the number of event matches and details of each event. You can view the following details:
    • Simulation ID: ID for this simulation run.
    • Data Origin: Data Origin of the data set the simulated scenario conditions are run against.
    • Jurisdiction: Jurisdiction the simulated scenario conditions are run for.
    • Batch Date: Date the simulated scenario conditions are run for.
    • Results: Number of event matches generated by the simulated scenario conditions during the run.
    • Event Details: Details for each event generated by the simulated scenario conditions during the run.
      • Event ID
      • Focus Name
      • Focus Type
      • Highlights
    If the simulation run fails, you can retrigger the simulation for successful run.
