Defining a Retention Type Enrollment Based Pricing Rule for a Bill Group Using a Pricing Group
Procedure
To define a retention type enrollment based pricing rule for a bill group using pricing group:
- Search for the Administrative Services Only (ASO) person, whose person type is set to Bill Group, in the Customer 360° View screen.
In the Search Results section, click
the View () icon corresponding to the person whose pricing details you want to view.
The Person tab appears in the Customer 360° Information screen.
Click the Pricing tab.
The Pricing tab appears.
Click the Broadcast () icon in the Bill Group
ASO Policy Information zone, corresponding to the Bill Group Information column, whose bill group details
you want to view.
The Bill Group ASO Policy Pricing Rules zone is displayed.
Click the Add link in the upper
right corner of the Bill Group ASO Policy Pricing Rules zone.
The Pricing Rule screen appears. It contains the following sections:
Main - This section contains the following fields:
Field Name Field Description Mandatory (Yes or No) Person Name Displays the person name. Not applicable Person Type Displays the person type. Not applicable Pricing Rule Type Used to indicate the pricing rule type. The valid values are: -
Aggregate Stop-Loss (ASL) Pricing Rule
Claim Pricing Rule
Discount Arrangement Pricing Rule
Retention Type Claim Based Pricing Rule
Specific Stop-Loss (SSL) Pricing Rule
Note: Select the Retention Type Enrollment Based Pricing Rule option, as the pricing rule type.Yes Note: If the pricing rule type is not selected then the application displays an error message.Pricing Group Used to indicate the pricing group for the bill group. Note: You must select a pricing group for the bill group on which a retention type enrollment based pricing rule is to be defined.Yes Policy Status Used to indicate the policy status for the bill group. The valid values are: -
In Force/Active
Post Runout
Runout
Yes (Conditional) Note: Policy Status is required once the Pricing Rule Type is selected. -
- Select the appropriate fields in the Main section.
Click OK.
The Retention Type Enrollment Based Pricing Rule screen appears. It contains the following sections:
Field Name Field Description Mandatory (Yes or No) Price Item Used to indicate the price item for which you want to define the pricing. The valid value are: -
Administrative Services Fees
Administrative Services Fees (No Mandatory Parameters)
AS_RET_ENRB
Consultant Oversight Fees
Yes Pricing Start Date Used to specify the start date from when the pricing will be effective for the price item. Yes (Conditional) Note: Pricing Start Date should be entered if Pricing End Date has been mentioned.Pricing End Date Used to specify the end date till when the pricing will be effective for the price item. Note: If the pricing end date is mentioned, once the price parameters and fees have been already entered, then the price parameter value and fee field values are reset.No Rate Option Used to specify the rate option for the price item. The valid values are: -
Flat Dollar Per Claim - Agg Daily
Retention - Aggregate Monthly
Claims
Percentage of Claim - Agg Daily
Yes Exempt Retro Transactions Used to indicate that retro transactions should not be considered for calculation purposes. No Pricing Group Rule Code Displays the code of the pricing group rule. Not applicable Description Displays the description of the pricing group rule. Not applicable Price Item Parameter Used to specify multiple price item parameters based on which you want to determine the price item utilization. Note: The Search () icon does appear corresponding to this field. On clicking the Search icon, the Price Item Parameters screen appears.No Parameter Value Used to specify multiple price item parameter values based on which you want to determine the price item utilization. Note: The Search () icon does appear corresponding to this field. On clicking the Search icon, the Parameter Value Search screen appears.No Fee Used to specify the fee for the price item parameter. No Note: If you want to define more than one price item parameter information, click the Add () icon. However, if you want to remove more than one price item or price item bundle, click the Delete () icon corresponding to the price item parameter. -
Characteristics - Used to define the characteristics for the Retention Type Enrollment Based Pricing Rule for a Bill Group Using a Pricing Group.
- Add the required details in the main and characteristics section.
Click Save.
The retention type claim based pricing rule for a bill group using a pricing group is defined.
If the approval workflow group setting is set as Active for the bill group, for which the retention type enrollment based pricing rule is defined then an approval transaction is created for that particular bill group. The retention type enrollment based pricing rule for a bill group using a pricing group is defined, once the approval transaction is approved.
Related Topics
For more information on... | See... |
How to define a characteristic for a retention type enrollment based pricing rule for a bill group using pricing group. | Defining a Characteristic for a Retention Type Enrollment Based Pricing Rule for a Bill Group Using a Pricing Group |
