Setting the C1_PER_REL Feature Configuration
You can define person to person relationship type sequence in the C1_PER_REL feature configuration. This sequence is used while searching for effective price item pricing at the parent customer level.
Procedure
To set the C1_PER_REL feature configuration:
Click the Admin link in the Application toolbar.
A list appears.
From the Admin menu, select F and then click Feature Configuration.
A sub-menu appears.
Click the Search option from the Feature Configuration sub-menu.
The Feature Configuration Query screen appears.
In the Feature Configuration Search zone, enter C1_PER_REL in the Feature Name field.
Note: ORMB search engine supports wildcard search, where you can substitute the percentage (%) symbol as a stand in for any word or letter in a search criteria. You can use the ‘%’ wildcard character in all input fields except the date and ID fields. The ‘%’ wildcard character is suffixed automatically at the end of the partial search criteria. Therefore, you may or may not specify the wildcard character at the end of the partial search criteria. However, you have to prefix the wildcard character manually wherever required.
Click Search.
A list of feature configurations that meet the search criteria appears in the search results.
In the Search Results section, click
the link in the Description column corresponding
to the feature configuration whose details you want to edit.
The Feature Configuration screen appears. It contains the following option types:
Option Type Description Mandatory (Yes or No) Person to Person Relationship Type Used to indicate the person to person relationship type. Note: If you want to define more than one relationship type in the feature configuration, you need to specify the sequence in which the relationship type should be considered while searching effective price item pricing at the parent customer level.Yes - Enter the values for the required option types in the Feature Configuration screen.
Click the Save button in the Page Title area.
The changes made to the feature configuration are saved.
Related Topics
For more information on... | See... |
Person to Person Relationship Type Sequence screen | Person to Person Relationship Type Sequence |
