MICROS Compact Workstation 310 Accessories
Table 5-4 Oracle MICROS Compact Workstation 310 Accessories
| Accessory | Description |
Enclosure for Battery (Enclosure for 83 Wh for Oracle MICROS Compact Workstation 3 Series basic and flexible stands) Part Number: 7118514
The MICROS Enclosure for Battery (optional) enables you to run the Compact Workstation 310 using battery power. Can be charged using the External Power Supply for Oracle MICROS Compact Workstation 3 Series (Part Number: 7119052). |
External Power Supply for Oracle MICROS Compact Workstation 3 Series Part Number: 7119052
The External Power Supply supplies power to the Compact Workstation 310 and can charge batteries installed in the Enclosure for Battery. |
Parent topic: MICROS Compact Workstation 310
