MICROS Compact Workstation 310 Technical Specifications
The following table contains the technical specifications for the Compact Workstation 310.
Table 5-1 Technical Specifications for the Oracle MICROS Compact Workstation 310
| Feature | 310 | 310R |
Processor |
Intel Atom x5-E3930 Processor @ 1.30GHz, 2C/2T, 2M Cache, (Apollo Lake) |
Display |
10.1 inches, 16:10 WXGA, 1280(H) x800(V), 262k colors (RGB 6-bits), brightness= 300 Nits |
10.1 inches, 16:10 WXGA, 1280(H) x800(V), 262k colors (RGB 6-bits) brightness= 800 Nits |
Customer Display |
256 x 64 Graphical OLED Display |
Touchscreen |
Projected capacitive touchscreen with 10-point simultaneous touch |
Memory |
4GB DDR3L @ 1600 MHz standard (8GB MAX) |
Storage |
64GB eMMC v5.0, 400MB/sec MAX. Non-removable. |
Operating System |
Microsoft Windows 10 IoT Enterprise (64-bit only) |
Magnetic Card Reader |
3 track, encryption-capable with Merchantlink encryption key pre-injected |
Network |
10/100/1G Ethernet, optional WiFi w/ Bluetooth |
USB |
5 Total:
Serial Ports |
2 Total:
Cash Drawer Ports |
2 Total. For use with Series 2 Cash Drawers. Dongle available to convert Series 1 Cash Drawers to Series 2. |
Power Supply |
External brick, 15V@5.33A (80W), 80~264VAC input. Optional battery power pack available. |
Weight |
Workstation only: 3.64 lbs. Workstation with Flexible stand = 9.0 lbs. |
Dimensions |
7.5 x 11.6 x 1.9 in / 191 x 294 x 47mm |
Operating Temperature |
0-50C (32-122F) |
-10-60C (14–140F) |
Resistance to Spills and Debris |
IP43 for Compact Workstation 310, IEC/EN 60529-22 |
IP55 for Compact Workstation 310R when using the supplied port plugs, IEC/EN 60529-22 |
Impact Resistance |
EN62262–IK07: Impact energy= 2.0 joules |
Parent topic: MICROS Compact Workstation 310
