e7 BOC Features and Requirements
Table 19-1 e7 BOC Features
| Feature | Specifications |
Processor |
1.6GHz Atom |
Display |
1 VGA Port, 1 DVI-D Port (Dual Display) |
Operating System |
POSReady 2009 |
Case Material |
Sheet Metal |
Weight |
2.5 lbs. (1.07 Kg) |
Physical Dimensions |
145mm D, 190mm W, 36mm H |
Mounting |
Depends on Application |
COM Ports |
2 RS232/RS485/RS435 |
USB Ports |
4 |
LAN Interface (2) |
10/100/1000 Mbps Ethernet - Modular RJ45 |
AC Input Voltage |
100 - 240VAC - 1.5A, 50 - 60Hz. |
Input Power |
60W Max |
Operating Temperature |
With Industrial Temp CF, Memory, and AC Adapter: -20°C (-4°F) to +50°C (122°F) With 2.5” Hard Disk Drive: 0°C (32°F) to 40°C (104°F) |
Storage Temperature |
-20°C (-4°F) to 70°C (158°F) |
Parent topic: e7 BOC or Digital Menu and Marketing System Controller
