e7 KVM Controller Features and Requirements
Table 23-1 e7 KVM Controller Features
| Feature | Specifications |
Case Material |
Aluminum |
Weight |
3.5 lbs. (1.5 kg) |
Physical Dimensions |
84mm D, 95mm W, 38mm H (3.30” x 3.70” x 1.50”) |
Mounting |
Shelf |
Video Output |
VGA |
COM Ports |
None |
USB Ports |
4 Type A, 1 Micro-B |
LAN Interface |
10/100/1000 Mbps Ethernet - Modular RJ45 |
External AC Adapter Input Voltage |
100 - 240VAC, 50/60Hz, 0.5A |
DC Input Voltage |
5VDC, 2.5A |
Operating Temperature |
0°C (32°F) to 50°C (122°F) |
Storage Temperature |
-20°C (-4°F) to 70°C (158°F) |
Parent topic: e7 Kitchen Video Monitor Controller
