Custom Cabinets and Enclosures
To maintain the internal temperature within the equipment at the specified levels, adequate ventilation is required. Do not mount the equipment in an enclosure that could impede air flow to all four sides. A three sided (front and back open) enclosure with 4 inches of clearance on all sides is acceptable.
