Location
Locate all equipment so that it is accessible to service personnel.
Tile is the recommended floor surface for areas surrounding the equipment. If the floor covering adjacent to the equipment is carpeted, an anti-static grade is recommended.
If the carpeting surrounding the area housing the equipment is not composed of anti-static material, the use of static discharge mats is recommended. The recommended type of anti-static mat is one that incorporates a grounding clip with a cable, to attach the grounding electrode to earth ground.
The Equipment Dimensions section contains dimensional information for each hardware device in the system.
