Cable Runs
IDN cable runs are installed in a multi-drop or daisy chain configuration to each device to form a network. For examples, refer to the Lan Cable Termination section. An Oracle MICROS approved RS422 cable is started at the wall plate near the workstation and is daisy chained to a wall plate near the first printer and so forth until all printers are connected.
The absolute maximum length of an IDN cable run is 4000 feet using shielded or non-shielded.
Parent topic: Traditional MICROS RS422 Cabling and Connection Hardware
