2 Oracle Workstation 8 Series
Overview
The Workstation 820 features a clean, modern design that complements any commercial space and provides the performance, flexibility, and reliability your business needs to succeed. Customize your Workstation 820 with accessories designed to integrate seamlessly with minimal setup time, or choose a preassembled Workstation 8 configuration to get up and running ASAP.
Available accessories:
- Vertical Stand: A modern, stable stand for the Workstation 820.
- Low Profile Stand: Rock-solid support with a reduced vertical footprint for the Workstation 820.
- Peripheral Expansion Module: Expanded connectivity options for current and future needs.
- Customer Facing Display for Vertical Stand: Mounts on the Vertical Stand.
- Customer Facing Display for Low Profile Stand: Mounts on the Low Profile Stand.
- Freestanding Customer Facing Display: 7-Inch Customer Facing Display with integrated kickstand that allows rapid countertop deployment.
- Customer Facing Display with Pole Mount: 7-Inch Customer Facing Display pre-mounted on a pole. Pole base supports cash drawer mounting.
