MICROS Keyboard Workstation 270 Features
Table 17-1 MICROS Keyboard Workstation 270 Features
| Feature | Specifications |
Processor |
FreeScale iMX27L |
Display |
5.7” 320x240 Operator LCD |
Operating System |
Windows Embedded CE 6.0 |
Memory |
128M Mobile DDR SDRAM |
Case Style |
Standard Low Profile or Optional Adjustable Stand |
Case Material |
PC-ABS Plastic |
Weight |
7.7 lbs. (3.5 kg) / Shipping Weight 11 lbs. (5 kg) |
Physical Dimensions |
The KW270 Equipment Dimensions section contains more information. |
Customer Display |
Integrated 2x20, LCD |
Optional Customer Displays |
Pole 240x64 Graphics Capable LCD |
Cash Drawers |
2 MICROS 4-Pin DIN Connectors - +12V or +24V jumper selectable. |
Serial IO Ports |
Accessory Power |
USB Port |
2 USB Ports |
LAN Interface |
10/100 Mbps Ethernet - RJ45 |
Input Voltage |
Universal Input - 85 to 264VAC, 47 to 63Hz. |
Input Power |
6W Typical, 63W Maximum (+15VDC @ 4.2A) External AC Adapter |
Operating Temperature |
Without Battery Pack: -10°C (14°F), to 65°C (149°F), 90% relative humidity non-condensing at 65°C (149°F). With Battery Pack: Charging: 0°C (32°F) to 45°C (113°F) Discharging: -10°C (14°F) to 60°C (140°F) |
Storage Temperature |
Without Battery Pack: -20°C (-4°F) to 80°C (176°F) With Battery Pack: -5°C (23°F) to 30°C (86°F) |
Parent topic: MICROS Keyboard Workstation 270
