Cable Types
The following data cable types are found in a typical installation.
Ethernet Cabling
In the electrically active environments that MICROS hardware typically operates, we strongly recommend shielded Ethernet cabling and connection hardware.
In electrically quiet environments, a certified UTP Category 6 or better cabling system and connection hardware is acceptable and does not void the hardware warranty. However, issues related to non-shielded cable may be subject to out-of-scope billing charges.
IDN Cabling
For IDN cabling, shielded cables or non-shielded cables installed in a separate grounded ferrous metal conduit are required.
Parent topic: Network Requirements and Planning
