MICROS PC Workstation 2010 Features
Table 13-1 MICROS PC Workstation 2010
| Feature | Specifications |
Processor |
Display |
Standard 800x600 12.1” TFT Color LCD, Optional 1024x768 TFT Color LCD |
Operating System |
Windows XP Professional |
Memory |
DDR-SDRAM: (2) Slots, 128 MB up to 2 GB |
Case Style |
Adjustable Display |
Case Material |
PC-ABS Plastic |
Weight (/w Hard Disk and VFD Display) |
With 12.1” LCD - 17 lbs. (7.7 Kg) With 15 LCD - 22.7 lbs. (10.3 Kg) |
Physical Dimensions |
The Equipment Dimensions section contains more information. |
Optional Customer Displays (Series) |
Pole 240x64 Graphics Capable Display with 2x20 emulation. |
Cash Drawers |
2 MICROS 4-Pin DIN Connectors - +12V or +24V Jumper Selectable. |
LAN Interface |
10/100 Mbps BaseT Ethernet |
COM Ports |
USB Ports |
4 |
AC Input Voltage |
Universal 90-264VAC, 47-63GHz. |
Input Power |
46W Typical, 242W Maximum |
Operating Temperature |
0°C (32°F) to 45°C (113°F), 90% relative humidity max. |
Storage Temperature |
-25°C (-13°F) to 80°C (176°F) |
Parent topic: MICROS PC Workstation 2010
