Standard Power Conditioners
All North American models have UL and cUL listings. International Models are safety agency listed and carry the CE mark.
Let-through voltage is <10 Volts normal mode and < .5 volts neutral to ground when tested to ANSI/IEEE C62.41.
Red flashing LED warns if the AC outlet is missing its input safety ground.
Figure 26-2 Approved Wall Mount PowerVar Standard Power Conditioners
The table below shows the approved power conditioners with the VA rating, output current, Oracle MICROS part number (PN), and number of outlets for equipment.
Table 26-3 Approved Wall Mount PowerVar Standard Power Conditioners
| Feature | ABC065 | ABC100-11W | ABC150-11W | ABC302-11W |
MICROS Part Number |
700247-074-PT |
700247-076-PT |
700247-078-PT |
700247-079-PT |
VA Rating |
78 |
120 |
180 |
360 |
Input-Output Voltage (VAC) |
120-120 |
120-120 |
120-120 |
120-120 |
Output Current (Amps) |
0.65 |
1.0 |
1.5 |
3.0 |
Frequency(Hz) |
60 |
60 |
60 |
60 |
BTU (/Hr.) |
27 |
41 |
61 |
123 |
Outlets |
2 |
2 |
2 |
4 |
Size (in.) (HxWxD) |
3.61 x 4.25 x 6.74 |
4.23 x 4.97 x 7.58 |
Shipping Weight (lbs.) |
5 |
6 |
6 |
11 |
Parent topic: Recommended AC Power Conditioning and UPS Equipment
