MICROS Tablet 700 Series Technical Specifications
The following tables contain the technical specifications for the Oracle MICROS Tablet 720 and the Oracle MICROS Tablet 721.
Table 6-1 Technical Specifications for the Oracle MICROS Tablet 720
| Feature | MICROS Tablet 720 |
Processor |
Intel Atom Quad Core, 1.33GHz |
RAM |
2GB |
Storage |
64GB Flash |
Operating System |
Microsoft Windows Embedded 8.1 Industry Pro Microsoft Windows 10 IoT Enterprise 2016 LTSB |
Display |
7-inch LED-Backlight Screen with Capacitive Touch |
Display Resolution |
1280 x 800 |
WLAN |
Wi-Fi 802.11a/b/g/n |
Bluetooth |
Bluetooth 4.0 LE |
USB Port |
USB 2.0 x 1 |
Headset Jack |
1 |
DC In |
1 |
AC/DC Adapter |
Input: 100 – 240V AC; Output: 5V DC, 3A |
Battery Pack |
Replaceable rechargeable Li-ion battery, 3.6V, 8800mAh Backup/Bridge Battery: 240mAh |
Enclosure |
ABS + PC plastics |
Dimensions (H x W x D) |
5.24in x 8.26in x 0.93in 133mm x 210mm x 23.5mm |
Temperature |
Operation: 0 °C (32 °F) to 40 °C (104 °F) Storage: -20 °C (-4 °F) to 60 °C (140 °F) |
Humidity |
0% to 90% Non-Condensing |
Weight |
1.31 lbs (0.59 kg) |
Magnetic Stripe Reader (MSR) |
Triple Track Readers (ISO TK1, 2 & 3), JIS & AAMVA Compliant |
Barcode Scanner |
Optional; 1D/2D Barcode Scanner |
NFC/RFID |
Optional; Supports ISO/IEC 14443 Type A, Reader/Writer Mode @ 13.56MHz |
Table 6-2 Technical Specifications for the Oracle MICROS Tablet 721/721P
| Feature | MICROS Tablet 721/721P |
Processor |
Intel Atom Quad Core, 1.44GHz |
RAM |
4GB |
Storage |
64GB Flash |
Operating System |
Microsoft Windows 10 IoT Enterprise 2016 LTSB Microsoft Windows 10 IoT Enterprise 2019 LTSC (Tablet 721P) |
Display |
1280 x 800 |
WLAN |
Wi-Fi 802.11a/b/g/n/ac |
Bluetooth |
Dual Mode Bluetooth 4.2, BLE |
USB Port |
USB x 1 |
Headset Jack |
1 |
DC In |
1 |
AC/DC Adapter |
Input: 100 – 240V AC; Output: 12V DC, 5A |
Battery Pack |
Enclosure |
ABS + PC plastics |
Tablet 721: 5.24in x 8.75in x 0.7in (133mm x 210mm x 18mm) Tablet 721P: 5.41in x 8.49in x 1in (137.5mm x 215.6mm x 26.4mm) |
Temperature |
Humidity |
Weight |
Barcode Scanner |
Camera |
Optional; Resolution up to 2592x1944px, 68° FOV, 3.94in minimum focus distance, F2.8±5% |
NFC/RFID |
Optional; Supports ISO/IEC 14443 Type A/B, ISO/IEC 15693, MIFARE Ultralight, FeliCa, Reader/Writer Mode @ 13.56MHz |
Parent topic: The Oracle MICROS Tablet 700 Series
