MICROS Tablet Multi-Unit Charger Features
Table 11-1 MICROS Tablet Multi-Unit Charger Features
| Feature | Specifications |
Charging Indicator |
R-Series Only – a pair of LEDs in each cradle displays the charging status |
Case Style |
Wall or Counter Mounted Charging Base that supports a maximum of 8 Charging Cradles |
Weight |
Shipping Weight = 4.5 kg (10 lbs.) With 4 Tablets = 11.3 kg (25 lbs.) With 8 Tablets = 15.9 kg (35 lbs.) |
Physical Dimensions |
The Equipment Dimensions section contains more information. |
Input Power |
40W Typical, 130W max /w 8 Tablets |
AC Input Voltage |
Universal Input - 85 to 264VAC, 47 to 63Hz. |
Operating Temperature (Charging) |
0°C (32°F) to 45°C (113°F) |
Storage Temperature |
-25°C (-13°F) to 85°C (185°F) |
Certifications |
FCC Class A, UL, CE, TUV, RoHS, China RoHS |
Parent topic: MICROS Tablet Multi-Unit Charger
