MICROS Tablet R-Series Features
Table 9-1 MICROS Tablet R-Series Features
| Feature | Specifications |
Processor |
Freescale i.MX6 Dual Core Processor ARM Cortex A9 Architecture 1GHz, 1MB L2 Cache |
Display |
10.1” WVGA (1024x600) TFT LCD /w LED Backlights Portrait or Landscape orientation and Auto-Rotation Two LCD options are available:
Operating System |
Windows Embedded Compact 7 |
Touchscreen |
Truly Projected Capacitive Touch Sensor that supports multi-touch and gesturing |
Memory |
1GB DDR3 SDRAM |
Storage |
4G Fixed NAND Flash 8G microSD Flash Card |
Backlight |
LED backlights with three intensity setting controlled by the Automatic Light Sensor or API |
Case Material |
Magnesium Alloy, PC-ABD, and Nylon materials Spill and drop resistant |
Weight |
830 grams (1.8 lbs.) |
Physical Dimensions |
16mm D, 176mm W, 292mm H (0.62 in x 6.90 in x 11.5 in) |
Mag Stripe Reader |
Modular Integrated 3-Track card reader capable of encryption at the swipe. |
Ports |
Charging Pins (for MICROS Tablet Multi-Unit Charger) Multi-function connector for Base Station (All signals between Tablet and Base Station) |
Network |
802.11 a/b/g/n Wi-Fi with WPA WPA2, TKIP, AES support Bluetooth V2.01 Wi-Fi/Bluetooth not available on Concessions Tablet |
Battery |
Embedded Lithium Ion (21.8Wh) Embedded Battery not available on Concessions Tablet |
Input Power |
5 VDC, 2.5A |
BTU/Hour |
120 Typical, 290 Maximum |
Operating Temperature |
-10°C (14°F) to 60°C (140°F) When Charging Battery: 0°C (32°F) to 45°C (113°F) |
Storage Temperature |
-25°C (-13°F) to 85°C (185°F) |
Certifications |
FCC Class A, UL, CE, TUV, RoHS, China RoHS |
Parent topic: MICROS Tablet R-Series
