15 MICROS Workstation 5
The Workstation 5 is a diskless/fan-less embedded workstation that can run either Windows Embedded CE 6.0 or POS Ready 2009. The figure below shows the low-profile workstation and the workstation installed on an optional adjustable.
The Workstation 5 Setup Guide provides instructions for the setup and operation of the Workstation 5 hardware.
Figure 15-1 MICROS Workstation 5
