MICROS Workstation 6 Series Adjustable Stand
The Workstation 6 Adjustable Stand provides a solid base for mounting the Workstation 6, a wide range of positioning for optimal viewing angle, enhanced cable management, integrated customer display mounting locations, and expansion options. The adjustable stand contains the following features:
High- and Low-Mount Customer Displays
USB Port
Printer Power Supply Storage/Expansion Module Location
DC Power Cable
3 Security Screws (Hex Socket Cap M3x6 MC Steel - Black)
2 for the cable management cover
1 for the workstation
Hex Key (2.5mm)
For expansion, the Adjustable Stand includes the following:
The adjustable stand includes a bracket that allows mounting of the Epson PS-180 Power Supply. An internal "Y" cable provides AC power to the Epson PS-180 Power Supply and Workstation 6 power supply.
The printer power supply storage location can alternatively be used for optional expansion modules, including a powered USB expansion module. You cannot use an expansion module and the printer power supply at the same time.
Parent topic: MICROS Workstation 610, 620, and 650
