Configuring Workstation Settings
From the BIOS Home screen, tap the Workstation option.
The Workstation Option on the BIOS Home Screen
Table 9-1 Workstation Settings
| Setting | Description of Option |
Cash Drawer Voltage |
Select 12V or 24V. |
COM Port Voltage |
Select a voltage for the COM 1 port:
12V Powered USB |
Enable or Disable the 12V Powered USB port. |
24V Powered USB |
Enable or Disable the 24V Powered USB port. |
USB Ports (1–6) After Shutdown |
Enable or Disable the USB ports 1-6 after the workstation has been shut down. |
USB Port 1 |
Enable or Disable USB port 1. |
USB Port 2 |
Enable or Disable USB port 2. |
USB Port 3 |
Enable or Disable USB port 3. |
USB Port 4 |
Enable or Disable USB port 4. |
USB Port 5 |
Enable or Disable USB port 5. |
USB Port 6 |
Enable or Disable USB port 6. |
USB Port 7 |
Enable or Disable USB port 7. |
USB Port 7 High Power Voltage (Battery Mode) |
625/655: Set to Disable and cannot be changed. 625E: Set to Available if a battery power source is detected. If required, change to Enable. |
422 Mode Selection |
Enable or Disable RS-422 mode for the IDN port. |
422/232 Mode Selection |
Select 422 Mode or 232 Mode to enable RS-422 mode or RS-232 mode for the IDN port. |
Power Failure Restoration |
Select the action taken by the system in the event of a
power failure:
Factory Recovery |
Select factory recovery settings:
Casework Open Actions |
Select the action taken by the system if the workstation
casework is compromised:
