Testing the Fingerprint Reader
The Fingerprint Reader screen lets you test the fingerprint reader’s ability to scan a fingerprint and validate the fingerprint read accuracy.
On the diagnostic main screen, scroll down in the list of devices, and then tap Fingerprint Reader.
On the Fingerprint Reader screen, tap Device Selection.
Tap Select to select the fingerprint reader device, or tap the Devices List drop-down and select your device.
Tap Acquire Fingerprint. The Enroll a Fingerprint screen appears.
To enroll a fingerprint, tap a finger on one of the hand icons. The Enroll a Fingerprint — Scan your finger screen appears.
Place your finger on the fingerprint reader and wait until success is confirmed. Ensure the finger you place on the reader matches the finger you chose in the previous step. For each successful enrollment, a number will turn blue starting with 1. A total of 4 enrollments per finger are allowed. After successfully enrolling a fingerprint, the screen disappears.
Tap Close on the Enroll a Fingerprint screen.
Tap Validate Fingerprint.
To validate enrollment, touch the fingerprint reader with the enrolled finger.
Valid fingerprint: OnIdentify: One or more matches. Try another finger.
Invalid fingerprint: OnIdentify: No matches. Try another finger.
