Technical Specifications
Table 2-3 Technical Specifications for the MICROS Workstation 655X
| Feature | Description | ||
Processor |
Intel Core i5-8265U Quad Core 1.6GHz |
Display |
Memory |
2 - SODIMM Sockets; 8GB DDR4L 2400MHz |
Storage |
Removable Recovery Media |
128/256 GB SSD. Allows rapid restore to the original factory condition. |
Operating System |
Magnetic Stripe Reader (Optional) |
Modular integrated 3-track magnetic card reader; capable of hardware encryption at the swipe. Merchantlink encryption key pre-injected. |
Modular Integrated Biometric Fingerprint Reader (Optional) |
Provides rapid identification and secure verification capabilities for recognition of individual users without requiring passwords or card swipes. |
RFID |
Integrated RFID reader for employee sign in. Reads 125 kHz and 13.56 MHz RFID tags. |
Audio |
Network |
USB |
Serial Ports |
3 Total Standard:
Adjustable Stand Expansion Modules (Optional) |
Powered USB Expansion Module:
Cash Drawer Ports |
2 - MICROS Series 2 cash drawer ports (12/24V selectable) |
Customer Display Port |
1 - MICROS DIN customer display port |
Power Output |
1 - 12V power out (2.5A) |
Expansion Ports |
Power Supply |
Supported Stands |
Workstation 6 Series Adjustable Stand, Workstation 6 Series wall mount, Compact Workstation 3 Series Flexible Stand, Compact Workstation 3 Series Basic Stand |
Weight |
Head unit: 5.4 lbs Adjustable Stand: 5 lbs |
Dimensions |
Workstation only: Approximately 366mm x 238mm x 42mm (9.37 x 14.4 x 1.65 inches) See Equipment Dimensions for more details. |
Operating Temperature and Humidity |
0 °C (32 °F) to 50 °C (122 °F); 90% Max relative humidity (non-condensing) |
Enclosure |
Certifications |
FCC Class A, UL, CE, TUV, RoHS, China RoHS |
Table 2-4 Technical Specifications for the MICROS Workstation 625X
Processor |
Intel Celeron 4305UE |
Display |
Memory |
Storage |
Operating System |
RFID |
Audio |
Network |
USB |
Serial Ports |
3 Total Standard:
Cash Drawer Ports |
Power Output |
Expansion Ports |
Power Supply |
Supported Stands |
Weight |
Dimensions |
Enclosure |
Certifications |
Table 2-5 Technical Specifications for the MICROS Workstation 625E
Processor |
Intel Celeron 4205U |
Display |
Memory |
1 - SODIMM Sockets; 4GB DDR4L 2400MHz |
Storage |
Operating System |
Audio |
Network |
USB |
Serial Ports |
3 Total Standard:
Cash Drawer Ports |
Power Output |
Expansion Ports |
Power Supply |
Supported Stands |
Weight |
Dimensions |
Enclosure |
Certifications |
