1 Preface
Audience
This document is intended for those who will be setting up, installing, and operating Oracle MICROS Workstation 625/655 workstations. It is not specific to a particular software application.
Admonitions
Unless specified, the information in this document applies to each configuration of the Workstation 6 Series.
The following symbols may appear in this document:
Caution: There is a risk of personal injury and equipment damage. Follow the instructions. |
Caution: Hot surface. Avoid contact. Surfaces are hot and may cause personal injury if touched. |
Caution: Hazardous voltages are present. To reduce the risk of electric shock and danger to personal health, follow the instructions. |
Depending on the type of power switch your device has, one of the following symbols may be used:
On: Applies AC power to the system. |
Off: Removes AC power from the system. |
On: The On/Standby switch is in the standby position. |
Customer Support
To contact Oracle Customer Support, access My Oracle Support at the following URL: https://support.oracle.com.
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to recreate
Exact error message received
Screenshots of each step you take
Documentation
Oracle Food and Beverage product documentation is available on the Oracle Help Center at http://docs.oracle.com/en/industries/food-beverage/.
Revision History
| Date | Description of Change |
March 2020 |
April 2020 |
May 2020 |
February 2021 |
October 2021 |
March 2022 |
September 2022 |
August 2023 |
October 2023 |
February 2024 |
