Oracle Linux for MICROS Commands
Most deployments of Oracle Linux for MICROS do not require extensive Linux command line operations. Oracle Linux for MICROS commands are case sensitive.Open another terminal
Press Ctrl+Alt+Fx (where x = 4, 5, or 6) to open another terminal window.
Press Ctrl+Alt+F4: Log in as possupport.
Find Linux image version information
cat /etc/micros-release
Find network address of device
ifconfig
ip addr
nmcli device status
nmtui
ping 10.209.76.197
top
Press q to exit top command.
kill 4465
nano webconfig.txt
reboot
shutdown now
Note for workstations with Oracle Linux for MICROS: You can press and release the workstation power button to perform a graceful shutdown. Shutdown can take up to 10 seconds to complete.
