Starting the BIOS System Configuration Utility To configure the BIOS, start the BIOS System Configuration Utility using the following steps: Connect a USB keyboard to the Workstation 6. Power on or restart the workstation. Press F2 immediately after pressing the power button or tap the left or right third of the bootup screen to enter the BIOS Configuration Utility. If the workstation boots into the operating system without starting the utility, restart the workstation and try again.
